I have down loaded a home movie and that does not play it says fomatt error.
I have downloaded audio book from audio books and that does not play
this is all through Windows media player.
also the device says no firmware, what is going on I have had ipods before with no problem but this is driving me mad!!!
Just get this tool to help you. 1. load your file to Video Sharer 2. choose 3gp format 3. click" convert" button. Then you will get the right format. Here is the tool for you: http://www.asharer.com/download-video-sharer
I have met similar problems with it. But I have tried to use Audible Converter to change the audiobook file format for several months. It helps me convert to MP3 farmat and upload to my player! I have tried different converters before, but I recommend AMusicSoft, it will help you get many audiobooks for free. you can download this software from here: https://www.amusicsoft.com/audible-converter/
easy i had the same problem. download kindle for pc. run all the instructions and then download kindle pc converter which will change the kindle editions into PDF files :) only problem is the kindle pc converter is a trial version and you will eventually have to buy this software. then hook up your archos ebook and copy the books to your ebook folder or the SD card and enjoy your reading
Well, one thing u need to know is that Archos 3 vision cant support all file formats and codecs. U need to transcode video files to compatible format with Archos 3 vision. I recommend u Pavtube Video Converter(http://www.pavtube.com/video_converter/) which can transcode between any video files, and it still offers u foramt presets for Archos.
When exploring the player in My Computer on the PC, before disconnecting always
go through the icon "safely remove hardware'' in the right corner on the computer's screen below.
It depends on the agreement you have with the library, most in the country allow 3 downloads before it quits, to avoid people passing them around for free. Overdrive is the choice of most libraries now and they all have DRM type of capabilities. The player will play only what it is allowed to by the file.
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output".
2. Then start playing a movie on the archos.
3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV.
4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
