Apple MacBook Mac Notebook Logo
Posted on Apr 10, 2010
Powerdirector 8 delux
Hi just wondering if the software powerdirector 8 delux compatible with Mac? it say windows 7? so will the powerdirector 8 delux be use with my mac book?
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 70 Answers
  • Posted on Apr 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
70
Questions
0
Helped
30427
Points
87
No you cant use Power Director in your Mac Os X. But if if you load Win XP in mac u can use it.For Mac OS you can use FCP or AVID for video editing.
What is the keygen for Cyberlink Powerdirector 7?
Sorry, but nobody on FIXYA is allowed to help you become a SOFTWARE PIRATE.
Purchase a GENUINE copy of the software, and you'll get a license-key.
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
I cant open saved files even when i right click open with pd8
Righ click then click open.It works for me, but my version is powerDirector 8 De-luxe
When opening to the Burn widow Just bselect andn double left click or sometimes itsa possible toleft click and drag and drop.
I'm not very experienced and I think power director leaves a lot to be desired and we shouldn't have to be reliant on websites for more information.
I need cyberlink powerdirector 8
Hi
Sabbrina
This is the link for the trial version which will only work for a limited period
http://www.cyberlink.com/downloads/trials/powerdirector/download_en_US.html
However if you need the full version with the crack this the link of the torrent file which you can download through any P2P software like utorrent , bittorrent etc..
http://torcache.com/torrent/2F54C286DCA6CB7B34C667964A31CC06689FA7EF.torrent
Thanks
Ashish p patel
http://www.youtube.com/watch?v=wGjjrsfQfDA
mastergani
2answers
Powerdirector 8 created dvds will not play
when i play my dvd's video it not work video can't display
Need Vista compatible CD ROM
Hello there,
Unfortunately, JVC is not offering the latest version of their Powerdirector on the website. You can however have the option to purchase it. This version already fully support Vista and Windows 7. Please see link below:
http://www.cyberlink.com/products/powerdirector/requirements_en_US.html
Pds file
File Type 1 PowerDirector Project File (Most common) Category Video Files Common? No File Description Video project or slide show created with PowerDirector, a digital video-editing program; may include both video and DVD data for creating a DVD; often built from a template included with the PowerDirector software. Program(s) that open pds files windows.gif Windows tri.gif CyberLink PowerDirector Sponsored Links window.google_render_ad(); Updated 6/5/08 star.gif Fix file extension .PDS errors.
File Type 2 Planetary Data System File Category Data Files Common? No File Description Scientific data format created by NASA (National Aeronautics and Space Administration); used to store planetary, solar, and lunar data collected from earth and space missions.
PDS files often contain labels that are written in the Object Description Language (ODL); these labels use keywords that describe the data contained in the file. Program(s) that open pds files mac.gif Mac OS tri.gif NASA PDS Tools Package windows.gif Windows tri.gif NASA PDS Tools Package
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
