Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
Anonymous Posted on Apr 10, 2010
Lavono 3000n100 laptop blackscreen problam - Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
  • 6 more comments
  • Anonymous Apr 10, 2010
    IT IS NOT BOOTING
    LAVONO 3000N100 LAPTOP IS NOT BOOTING AND ALSO BLACK SCREEN ,RAM OK,HOW TO FIX IT
    i tried that 5 min press switch method ,the problem is not solved.the ram also ,i replaced a working one.
    except the power on led no other led is coming on and off.but the cpu fan alone comes on and off for few second.praying for your replay.
    regards.
  • Anonymous Apr 11, 2010
    the mother problem,? how to confirm that?.if so where to look next?and how to solve the problem.waiting for your answer.
    best regards,
    dharmakkan
    LEVONO3000N100 LAPTOP.
    1.BLACK SCREEN
    2.NOT BOOTING .
    3.ONLY POWER ON LED IS ON,THE HEARD DISC LED FLASH ONCE AND GOES AWAY.
    4.FAN AND DVD ARE RESPONDING.
    I HAVE DONE:
    1. CMOS RESETING,
    2 BY PRESSING F7 FOR 5 SEC TO RESTORE SCREEN.
    3.IT LOOKS LIKE MOTHER BOARD PROPLEM OR ELSE?
    BEST REGARDS,
    DHARMAKKAN.
    1.BLACK SCREEN
    2.NOT BOOTING .
    I HAVE DONE:
    1. CMOS RESETING,
    BEST REGARDS,
    DHARMAKKAN.
  • Anonymous Apr 12, 2010
    thanks,but there should be a way to find out this problem.Because in chennai(india) there are some people not much qulified and with out sophisticated instrument they are able to change the component to solve these kind of problems.if i did not get solution from you ,i am going to give them.For me no other option.
    Any way i am waiting for your reply.
    best regards,
    dharmakkan.
    levono 3000n100 not booting and blank screen
    cmos reseting done,
    F7 KEY pressed ,
    your another expert says board problem but still i want go detail in board level if required.kindly go through earlier e mails,.
    best regards,
    dharmakkan.
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Apr 12, 2010
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
784643
Points
9440
Hello.
Assuming the laptop is powered on (green light), connect an external monitor. If the external monitor works, then your display (inverter) needs replacement. If an external monitor doesn't work, then your VGA in the laptop is faulty.
If the laptop is not powering on, could be the power adapter or power jack, which would need replacement.
If these suggestions don't help, please provide more info as to your problem and what you have tried to resolve.
Hope this helps.
    So sorry. Didn't see ALL your comments. When booting the laptop, try wiggling the power adapter cable where it connectsto the laptop. If loose, or the laptop powers on and off, you have a faulty power jack. Can be replaced or repaired (soldered - only try if you are knowledgeable)
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
  • Posted on Apr 11, 2010
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065039
Points
206
Hi! If its not turning on please check the power source for it may not be working. Plug the pc to a working power source. If no luck and the pc still doesnt respond then i believe that you have a faulty power supply or a faulty mainboard/motherboard. Have this check and replace if necessary. Hope this helps and have a good one!
A
Anonymous
Backup your data using an external monitor plugged into your laptop and then reinstall the operating system using the original restore CD. If you don't get a picture on the external monitor then you will need to replace the video card and/or hard drive
http://forums.lenovo.com/t5/Lenovo-3000-and-Value-line/Lenovo-3000-N100-Teal-Color-Lenovo-Icon-at-Power-Up-then-Windows/m-p/63022
Anonymous
Level 3:
  • Master 952 Answers
  • Posted on Apr 10, 2010
Anonymous
Master
Level 3:
Answers
952
Questions
Helped
198418
Points
2713
Thanks for using FixYa.
If your laptop's screen had suddenly turned black, you need to get the LCD repair kit for the laptop. The repair kit includes the LCD flex cable (this usually gets brittle and breaks) and other cable connectors for the LCD. Just bring the laptop to a local laptop repair shop and they should be able to fix it for your right away while you wait.
I hope this helps. Thanks and good day.
HotRatchet
Anonymous
Level 3:
  • Master 11,896 Answers
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734523
Points
36074
Unplug the pc, then remove the battery, the press and hold the power button for 5 full seconds. Then wait a minute and put battery back in, and plug it back in and turn it on. It should be good now. If you still dont have a picture, then you could have a bad memory chip
    If the reset didn't work, and both memory cards are new, and you get fan power but no leds or screen, then I would assume either the motherboard is bad.
    I still believe it's your board. Most act that same way when they go.
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
Master
Level 3:
Answers
6993
Questions
Helped
1700060
Points
1261
there are different reasons that could make your computer be in a black screen state:
  1. The screen might be bad and needs replacement.
  2. The screen inverter might be bad, this will not allow the screen display anything.
  3. The screen back light also may have died/burnt and will cause the screen not to display anything.
Also, to be sure one of the above is the problem, connect your laptop to an external monitor, and see if there will be any display. If there is a display, then one of the three problems stated is the problem.
But if there is still no display, then it means you laptop motherboard is the cause of the problem.
So I would advice that you take the laptop to a repairer to help help fix the problem.
Good luck.
How to clear blackscreen for windows 7 before login
Hello there anvesh_t416 if i got it right you have a blackscreen of "death" if you can get into safe mode, Navigate to the Start -> All Programs -> Accessories -> System Tools program group then click on system restore and see if it gets to a point that this stops. If you cant do that then your only option is to format your pc...
tip
My laptop shows blackscreen so i reformat it and now its not anymore showing the...
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 15, 2010 • Computers & Internet
Blackscreen on start.no display
Try the extension RGB monitor socket on a monitor to see if that works. If it does you might have hit the function key to switch the display to externel. Look in your manual about switching displays this will help you.
It will be something like <function F4 or something similar.
4helpful
2answers
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
How i m able to listion voice both of my builtin speaker laptop
use the volume control and put everything in the middle
Lenovo 3000n100 laptop needs drivers for sound for vista primum
Go to the Levono Website and click on support. On the search area type in "sound card drivers". You will be able to download it from the website.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
