I have a mp1 will not light and pumping fuel
Your problem may be a dirty flame sensor which can be cleaned with some steelwool. If the heater makes a ticking or thumping noise before it cuts off it is not getting fuel to the pump and you would need to check your filter and also the strainer in the fuel sump. Make sure you don't have water in your kerosene either. You can find an owner's manual at www.monitorproducts.com which will give you some more info.
Does the heater give any codes when it cuts off. Also what model do you have? There should be a number on the front such as 41, 441, 422, 2400, 2200 etc.
What model stove do you have? Have you checked your fuel? Let us know, Tom
