Question about Toshiba e-Studio163 Copier
My copier E 163 0 signal blinking
My copier E 163 0error code signal blinking
What is it? any one help please?
Posted by Tareq Bin Mostaq... on
digivisionm
    New Friend:
  • 40 Answers
Check scanner ribbon cable and replace it. BR
Posted on May 25, 2010
Feature light blinking
Ext 163 called you, and pressed # or * to leave a callback request. Call 163, make sure they answer by lifting handset, should go away.
Jun 11, 2014 | NEC Electra Elite 32D-1 Corded Phone
Red spaner blinking plz help me?
When the key of the digital keys and the [CLEAR/STOP] button are pressed simulta-neously, an error code (consisting of a letter of the alphabet and numbers) appears on the LED display.
What is the error code?
If "C4x" error code, perform 08-400, reset the value to "0".
Jul 09, 2012 | Toshiba e-Studio163 Copier
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
My Toshiba e studio 163 coupier machine key board not functioning, a spanner mark continue blinking which is located on front panel. Please send me solution.
you have a error code you must press 8+clear buttons down together and it will give you a code i must know what the code is
Feb 20, 2011 | Toshiba e-Studio163 Copier
Has a error code on display C-6 and then 400 blinking
press and hold Stop key start key and left exposure or light key. Release them then press stop. machine will show U000. Enter 163 using the scroll up and down keys. Press start key twice. the machine will initialize.
Jan 24, 2011 | Copystar CS-1500 Copier
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
I want reset my estudio 163
Press *+1+3 and power on the machine.
Nov 29, 2008 | Toshiba e-Studio163 Copier
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Toshiba e-Studio163 Copier Logo
172 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
