Question about Sharp MX-2700N Color Copier
When i start sharp- mx27004 printer then show problem is ''call for service code f2-40''
Posted by abhijitpal8 on
NinaE
    President:
  • 3,278 Answers
Hello.
Sounds like you need a service call. But, the tech should first check/inspect the Drum, Transfer Unit, and Fuser Unit and then reset your counter.
Hope this helps.
Posted on Apr 10, 2010
How do i fix a problem when AR5518 SHARP COPIER DOES NOT VERY WELL AND SHOWS F2,40
It sounds like a defective toner cartridge. You can try removing it and shaking it well and then Reinstalling it. Power the machine off and back on and see if it works. If that doesn't work you can try another toner cartridge. Also if the cartridge is empty and you keep installing it, it will disable the cartridge and the code will come up immediately when that cartridge is inserted.
Mar 31, 2015 | Sharp Office Equipment & Supplies
How do i clear error code F2-64
The news is not good. Follow the link to see what you are up against.
Error Codes Sharp MX2310U Code F2 64
Mar 04, 2015 | Sharp MX-2310U Color Copier, MX2310U "
Call for service . code : F2
There are several F2 codes. If you press and hold the start / copy key the machine will show your sub code. Re-post quoting full code and we can try to help.
Jan 24, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Sharp ar-c330
Hi gw16336
It means the mainboard has a malfunction. The printer would need to be serviced by Sharp or a Sharp approved service centre.
May 01, 2009 | Sharp AR-C270 Color Copier
Call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Jan 16, 2009 | Sharp MX-2700N Color Copier
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Feb 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Sharp MX-2700N Color Copier Logo
185 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
