The unit will say "no disk" if it is unable to read your disk ... that is often caused by dust or debree on the laser or the laser could be damaged ... the laser is the little lens that you see when the lid is open ... you can clean that with a soft tissue and some eye glass cleaner ..dont spray directly on the laser .. spray only on the tissue . very gently clean and dry the laser ... its mounted on a flexible mechanism so you have to be careful not to stress it ... also clean your disk . if the laser cleaning doesnt help then it may be damaged or worn out .. make sure the laser wiggles freely as if it was on a spring ... make sure the disk is actually turning .. you can listen for it to spin up .. ...
