Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PT-47WX53G. TV got moved. Unable to move blue
PT-47WX53G. TV got moved. Unable to move blue crosshairs to the right, under coverage adjustments. what has to be done to adjust.
Posted by jncdpont on
Sonny Berry
  • Panasonic Master
  • 8,617 Answers
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Posted on Apr 10, 2010
2answers
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
2answers
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
1helpful
2answers
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Picture pretty good but vertical lines (shadows) and ghosts
You're going to have to be more specific. When you are messing with the convergence settings, are all of the crosshairs straight lines? Are they crisp or fuzzy? Can you successfully move the Red and Blue crosshairs up/down/left/right? Have you opened up the TV yet? I'll help you from there once we get some details.
1helpful
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
1helpful
3answers
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Can not move blue colour to the right, will not aline.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Open Questions:
0answers
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
