Question about HP LASERJET P1006 Printer
My printer is making an extremely loud noise like a jackhammer when it tries to pull paper
Posted by reikorogozen on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
You need to get it serviced. I have never encountered that problem, but I recommend getting it serviced
Posted on May 31, 2019
5 Related Answers
Anonymous
  • 202 Answers
SOURCE: Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Posted on Mar 06, 2007
Inky
Inky Fingers
  • 705 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
pagebor
Rajkumar Bordoloi
  • 2785 Answers
SOURCE: Printing an 8x11 sheet the printer cradle makes a horrible noise
your printer needs servicing
Posted on Jan 07, 2009
1861bohdan
Lyudmyla Zuk
  • 3 Answers
SOURCE: IBM 9068-A01 printer loads paper crooked
I have 20 IBM 9068 at work and some of those problems I had also. The noice can come from Ribbon drive assembly. This part has plastic weels inside and tooth on it is droken. You have to open printer and check that part. If you need more info you can e-mail me at [email protected]
Posted on Apr 03, 2009
steveparlin
steveparlin
  • 61 Answers
SOURCE: weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Posted on Sep 01, 2009
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
Hp 4240n
mechanical check
Dec 18, 2013 | HP LaserJet 4240n Printer
Making loud noise ml1650 printer jam paper feed paper feed problem paper jam
Pull out a paper cassette and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Nov 21, 2010 | Samsung ML1650 Printer
Weird noise from printer carriage
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Paper feed
Hi there.
First of all pull out the paper jam cover - is behind the printer with a clock-like handle. Pull it out and check for any paper or other objects. If U dont see anything try to manualy rotate the black rubber rollers and check for that noise. Locate it and try to describe what you see.
Jun 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Loud noise/paper tray not working
What error? Does it say paper jam and a number? Have you tried cleaning the rollers that pick up the paper? Use a cotton cloth with a little bit of WD40. Then a dry cloth to remove residue oil. Do not use alcohol. It will dry out the roller and make it slick.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 08, 2007 | Ricoh Aficio AP410N Laser Printer
Mar 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP LASERJET P1006 Printer Logo
301 people viewed this question
Ekse
efs_perpends
efs_perpends
