Repair the OS using external cd/dvd drive connect ted via USB, Change boot order to usb drive on the first boot priority.Follow the instruction
Good luck
SOURCE: HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
SOURCE: not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
SOURCE: Windows xp will not boot on my hp mini 110.Keeps
Try selecting Last Known Good Configuration, or Safe Mode, and use System Restore option to go back to a date where the system booted correctly.
If neither of these options work, then you need to try to get into Recovery Console:
SOURCE: MY HP MINI 1000 HAS
The posible problem of your notebook is the operating system may be corrupted or could not detect your hard drive because of cable connection has loose from board to HDD or totally damage. Try to use another working HDD for isolation properly.
SOURCE: I recover the operating system
Go into the BIOS by pressing f10 when powering on the laptop.
Go to System Configuration and choose Device Configuration
Scroll down to SATA Native Mode and disable.
Press f10 to save configuration. The computer should reboot and press f9 to select boot device.
See if the 160GB hdd is now showing as an option. If it is then you are in luck.
p.s: You may need to update the BIOS to the latest if it still does not show up for you.
Testimonial: "thanks for your solution. but, how I can update the bios?"
thanks - that's when I get the disk i/o error - anything else?
