Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Clorine test by county health failed, what
Clorine pump needs replacing? clorine test by county health board failed, what happened
Posted by jamc1_1999 on
GPEC
    New Friend:
  • 12 Answers
The first thing I would check is the chlorine pump's element tube (squeeze tube) The element tubes often get worn out and stop drawing chlorine through the pump and into the wash tank. Most chemical supplier will have these element tubes. The element tube is located in the chemical pump. The chemical pump is usually located just inside the front lower service panel of the machine.
Regards
Posted on Apr 09, 2010
How do I get help for a bad smell around my home. it is driving me out off my home .maybe a drug cooker.
Call the police or county health dept. Your problem could be as little as a blocked drain or as big as the guy next door you haven't seen for a couple of weeks, dead in his arm chair!! Get online find your county health dept and make that call. If you have town gas to your property, mention that, that usually perks them up a bit.
Good luck.
May 20, 2014 | Computers & Internet
Failed smog check
you need to ask each place individually where the truck was tested..usually its the same in each part of the state..as my experience has been .. compare the differences if any,,
Dec 24, 2013 | Toyota Pickup Cars & Trucks
What can I do for cloudy greenish water
make the priority fixing the water with an overdose of chlorine making sure to not use the pool for swimming while doing this, after the green goes, and you will know when you have put enough chlorine in when it clears up, then re adjust your pH level. after the level is correct, use the pool as normal .
Jun 10, 2013 | INTEX Sand Filter Pump
Our system continues to give a 90 code reading even though we have a big enough filter pump to push enough water through the system. Everything is tight and the system is clean. how do we correct this...
Code 90 indicates that the water flow rate is not high enough for the system to operate properly. This is measured by a white plastic piece hinged from the top of the pipe. As water flows by the plastic piece gets pushed back and up against the top of the pipe so that it touches a sensor. A couple of solutions are as follows or a combination of these:
1) make sure that all pipes and filters are clean and clear. Leaves or other stuff will slow the water flow.
2) check that the clorinator is clear of any blockage or dirt.
3) unscrew the flow meter and pull out to check that the hinge is clean and the plastic piece moves freely.
4) when you put the flow meter back in place try turning it ever so slightly which might make a difference. This has worked sometimes for me.
5) make sure that the clorinator is level. I tilted my unit so that the inlet side is slightly higher than the outlet as an experiment and this works as well since I was trying to get the flow valve to travel less distance.(it's a geometry issue)
6) make sure there is no air stuck in the lines. Try lifting the pipes/tubes to move air out and make sure you bleed your pump to ensure that it is full of water and there is no air trapped here that would reduce flow.
7) try taking any nozzle off the hose going into the pool. These may slow the flow coming into the pool and cause back pressure in the pipes.
8) I have a solar panel with a bypass valve. The clorinator only works when I run the water using the bypass valve so that no water runs through the solar panel. Try running all water only through clorinator with no other devices in line to slow the flow or produce any restrictions.
9) Try running the clorinator but take out the pump filter as an experiment. The filter may need replacing. Taking the filter out should tell you if this is the case if the clorinator works without the filter in place.
10) As a last resort check the flow rate requirements for the clorinator and on the pump you have. The pump may be undersized.
Jun 26, 2010 | Intex Automatic Salt Water System for ...
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
I was given a jenn air stove and we plugged it in and it wont stopped beeping and it says F-7. How can we get it to stop?
Unplug it. Or replace touch pad (55% chance) or main board (45% chance). You can test it be disconnecting the touch pad and see if it keeps beeping, then it's the board.
Jenn air oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Cooktops
My water turns green when we shock it I have drained twice now Please help!!!
start with testing your chlorine and ph add liquid shock and conditioner to water dont use algecide you have to get clorine to open up this is critical ph clorine and conditioner you should get a good clorine reading or you have to add more shock
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Code E 70 on a 6000
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E56 Highmotor current. Refer to test (9)
E5A High temperature on heat sink. Test first if bad replace
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
May 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing machine error code on Frigidaire ATF6000E
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
231 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
