Question about Coby MPC-848 MP3 Player
My Coby MP600 4g won't let me delete songs. How can I fix this? The "delete" is de-highlighted, so I can choose it.
Posted by cjones631 on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: can't delete songs from coby mp-c827 player
Use Windows Media Player:
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Posted on Jul 24, 2008
Anonymous
  • 3 Answers
SOURCE: My Coby MP-705 Won't Let Me Delete Songs
Make sure your player is not active. Unplug it from your computer and turn it off. Now plug into your computer. Go to the start menu on your computer and select "run". Type in the port your unit is plugged into or use the dropdown and select. This should display your 705 contents. Highlight the file you want to delete, then right click and select delete. Hope this helps.
Posted on Jan 11, 2009
Anonymous
  • 4 Answers
SOURCE: My Coby MP-705 Won't Delete Songs
I had the same problem - VERY frustrating. Just found the answer, and am very happy to share it!
1. In setting/USB mode, select MSC mode.
2. Plug in Coby to USB
3. Open My Computer. Look for the Coby as a REMOVABLE DISK, not the Coby.
Files will be there for Viewing and Deleting! (On XP, at least).
4. Make a backup of MTP.BIN and WMPInfo.xml, which I think is the operating sytem?
I got the clue from here:
http://www.fixya.com/support/t357600-problem_coby_mpc7095_2_gb_mp3_player
Paupaul
Well, turn on you mp3 player, go on setting/USB mode and select MSC mode.
Then plug it on your computer and check in MICIN.DIR folder. You must find them.
It wasn't exactly what I saw, but once I looked, it was all there. Perfect!
Posted on Mar 04, 2009
Anonymous
  • 7 Answers
SOURCE: Deleted songs are still there!
I agree with profalwg, use Windows Explorer. When you connect the player's USB cable to the computer, a window should open...click on the option to open with Windows Explorer. If you delete files and they still don't go away (happens sometimes) go into the player's Setup menu & change the USB setting to MSC. Doing this corrects 99% of player recognition problems. Hope this helps!
Posted on Aug 28, 2009
YourZEN
YourZEN
  • 820 Answers
SOURCE: how to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
Posted on May 11, 2010
How do i delete songs ( and all other media) from my coby mp 815?
Choose "Explorer" from the main menu, highlight any file and press the 'Option" button (lower right hand side" You will see the "delete file" option
Jan 20, 2011 | Coby MP815 Digital Media Player
How do I delete songs from my Coby MP705
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
Dec 27, 2010 | Coby MP-705 Digital Media Player
I am using my Coby MP3 on a new computer. It won't let me add or delete files because it says it's protected, how do I fix this?
Books, Apps,etc. from MP3 Player/Ipod
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 07, 2010 | Coby MP300 MP3 Player
How do i delete a song on my coby mp600 4g
Books, etc. from MP3 Player/Ipod
Good Luck,
I hope this helps
Thank You
May 24, 2010 | Coby MPC-848 MP3 Player
MP705-4G HOW CAN I DO TO CLEAR SOME FOR MY SONGS?
Connect the player to your PC. When it appears in "My Computer", navigate to the songs you want to delete, highlight them and delete .
Apr 09, 2010 | Coby CBY705 MP3 Player
Cannot delete files
Try this solution to your proplem
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 12, 2009 | Coby MP-610 MP3 Player
It wont let me download any new songs it says that it can not be edited (playlist) so how do u download songs to it
try opening your player as a portable device. then on the right panel of the windows media player, you can see the list of songs. from there, highlight the songs you want to delete, right click then choose delete
Mar 05, 2009 | Coby MP-C582 MP3 Player
Just format your player and it should get rid of everything, including the preinstalled junk. Right click 'internal storage' and select format.
Jan 03, 2009 | Coby MP-705 Digital Media Player
Getting songs off mp3 player
My Directions:
-Tha Mp3 Doctor
Jan 01, 2009 | Audio Players & Recorders
Coby mp3 player
plug it into your computers usb port (or via cable if required).
go to my computer and you should see a new icon (possibly D: drive or removable drive)
open that.
the will either be a list of all the music or a folder to go to with the music in it.
select each song (one left click of mouse) or songs by dragging the mouse with left button down and then delete them (right click and choose delete).
do a happy dance.
Jun 29, 2008 | Coby MPC-848 MP3 Player
Coby MPC-848 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Jean Sintulaire
aliasger yq
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
