The ballast board controls the lamp. This board is failing. The lamp assembly wires connect directly to this board. You can get new parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
If this is in the form of a vertical stripe, the likelihood is that either the display panel is faulty or the ribbon cable is loose. Try reconnecting the ribbon cable inside. If this does not solve the problem, I suggest you try a repair shop who will have the spare parts necessary to diagnose the problem.
It is convergence problems.Any kinds of out of focus and colors misaligns.U know how to solders wright?Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Found it here: http://www.discount-merchant.com/Samsung-BP96-00677A-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00677a-lamp-oem.htm?Click=48173 If you've replaced the lamp before it might be the board that powers it ,it's called the ballast.Good luck nad God bless you!
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
