TRT MX174S 17" Flat Panel LCD Monitor Logo
Question about TRT MX174S 17" Flat Panel LCD Monitor
NO DISPLAY TRT 17 " TFT LCD MONITOR POWER CORD MODEL NUMBER MX174 My Doctor gave me this monitor. He was going to get rid off it but he gave it to me some how his staff misplace the power cable. Can you tell me which power cable will work with this monitor. I want to do performe some troubleshooting with this monitor however I wont remove the the cover because of store electricity. I like the refresh rate on this monitor. I am willing to purchase the Power Cord. I suspect the power cord was faulty but I could be wrong but I'am willing to take a chance. THE SERIAL NUMBER FOR THIS MONITOR IS S/N 170501000544 POWER INPUT 100V-240V ~ 50-60 hz Number 83912300910 - This number is under the Mickey Mouse Plug of the LCD Monitor. If anybody no the requested info I will certainly appreaciated. Thank You ................................... Irving
Posted by nezmusicpro1 on
Bud Martin
  • 11,361 Answers
Http://quail.com/seriesPage.cfm?seriesID=87 NEMA5-15P to IEC IEC-60320-C5
PC repair shop should have this power cord since it is used a lot for Laptop AC adapters.
If it still does not power up, then you may have to look inside, see my pictures so you know what to look for inside the monitors that is more than 2 years old.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Post post back so it may help other people also.
Posted on Apr 10, 2010
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
2helpful
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Lcd flat screen trouble blank screen
Please check your CPU ram I thing problem in ram.
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Top TRT Computers & Internet Experts
Marvin
Marvin
Are you a TRT Computer and Internet Expert? Answer questions, earn points and help others
