Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
I can't select more than one function to graph It only will let me select one function
Posted by wpajsmith on
Anonymous
    New Friend:
  • 3 Answers
In order to select additional graphs, the Transformation Graphing Application will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family.
More information regarding this matter can be found in the Knowledge Base. The Knowledge Base can be accessed by clicking on the URL below:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=65121&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG14E1108A3A0CD3ABADCD67260B59BDE0CEEA20790F80F708D8A4FDACCD82D31F792BC1B01D2F67ECAE6718104B82CC1C8F
Posted on Apr 09, 2010
How to graphing regarding ohter axes?
Add a graph .
In Documents Toolbox, select 3: Graph/Entry Edit
Unfold the menu and select Equation (not function). Enter your equation.
For the 3D part, I am afraid you will have to read the manual.
Jan 22, 2016 | Texas Instruments TI-Nspire CX CAS...
How do I graph sinx on my Casio fx-9750GII calculator?
Turn calculator ON
If you see no icons, press Menu
Press 3 (Graph) draw your function. (more on that later).
If the first line of the display show Graph Func : Y= you should be able to draw your function.
If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=.
After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw.
Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Feb 21, 2013 | Casio CE CASI FX-9750GII-L-IH GRAPHING...
How do i graph?
The fact that you are asking how to graph makes believe that you solved the problem about 'invalid dimension' . I am glad that worked for you.
This
should help you setup your calculator to do graphing.
1. Prepare calculator for graphing
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
2. Setup Graph type
  • Press [MODE] key.
  • In Mode set up screen, make set the angle unit (if you are drawing trigonometric functions)..
  • Use the arrows to move cursor to 3rd line to highlight degree or radian and press [ENTER]. The important thing is that you be aware of the unit so that you do not get unexpected results.
  • On same screen, verify that Func is highlighted. If you are drawing PARametric plots, POLar plots or SEQuence plots, you highlight the relevant item in the list
  • If it is not, use arrow to highlight Func and press [ENTER] to validate.
  • Do not worry if you do not have exactly the same screen as in the screen picture (We may have different OS Versions)
3. Entering the functions to draw (assuming you want to draw y= functions)
  • Press [Y=] to enter function editor.
  • Type in a function
  • Press [ENTER] at the end of each function.
  • Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  • In the screen capture 4 functions are slated to be drawn.
4. Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
  • Select the graph style: The small piece of line to the left of a Y that defines a function is the style.
  • Move cursor on it and press [ENTER] .
  • Each [ENTER] (on same line) selects another style.
  • On the next screen you have all the styles available on the calculator.
  • Do not select the bubble on line 6: It is for animations. It will not leave a trace at the end of the plot.
5. Drawing the Graphs
  • Press [GRAPH] to see the graphs.
  • If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions,
  • Here are the dimensions of the standard window
6. ZOOMING
You can also press [ZOOM] to adjust.
The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
Sep 08, 2010 | Texas Instruments TI-84 Plus Silver...
How can i draw graph.
This should help you setup your calculator to do graphing.
2. Setup Graph type
  • Press [MODE] key.
6. ZOOMING
Sep 03, 2010 | Texas Instruments TI-83 Plus Calculator
I can't graph on ,y ti 84...
Prepare calculator to graph
Setup Graph type
  • Press [MODE] key.
Drawing the Graphs
ZOOMING
May 19, 2010 | Texas Instruments TI-83 Plus Silver...
Graph drawing problem
Read the first part of the answer to deactivate the statistical plots. No need to read the rest if you know how to do graphs.
Setup Graph type
  • Press [MODE] key.
Drawing the Graphs
ZOOMING
Apr 25, 2010 | Texas Instruments TI-84 Plus Silver...
Cannot graph
Setup Graph type
  • Press [MODE] key.
Drawing the Graphs
ZOOMING
Apr 25, 2010 | Texas Instruments TI-84 Plus Calculator
Only graph one function at a time
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T), Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  4. Calculator displays Done
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognize that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays Inequal RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Mar 18, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator doesnt graph two equation on the graph
  3. Press [ENTER].
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
  1. Press [Apps]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Mar 17, 2010 | Texas Instruments TI-84 Plus Silver...
My graphing on my ti 84 isnt working
Setup Graph type
  • Press [MODE] key.
Drawing the Graphs
ZOOMING
Mar 11, 2010 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
139 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
