Onkyo TX-SR602 Receiver Logo
Posted on Apr 09, 2010
Powered zone 2 is not activated onkyo txsr602
tbdnrk
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 20, 2011
tbdnrk
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
3549
Points
10
You have to make sure that you have activated zone2 in setup? It is defaulted as 7.1 Activating zone2 makes it 5.1 + 2 (make sense)
Also zone2 only outputs audio hooked up thru the analog connections
1helpful
I have the Onkyo TX-SR605 system. My Zone 2 used to work and now it doesn't. I tried to activate it under the Hardware Setup, but Zone 2 does not show up. Any suggestions where else it can be found
Hello, When you say Zone 2 doesn't show up do you mean that its not there at all, or is it just greyed out? I would suggest a reset of the unit it seems as though either way it could be a glitch. Thanks, FJD
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
6helpful
Zone 2 stopped working. When pressing the volume button for Zone 2 , message appears : "Pwrd Z2 not Act." Do you know how to correct?
Go into Hardware Setup, find the setting for Powered Zone 2 and ACTIVATE IT. You will lose the Surround Back speaker function when you do this. Zone 2 and Surr Back are mutually exclusive.
2helpful
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Outdoor speakers on Zone 2
Hello Fixya customer,
Thank you for your question.
Please verify that Zone II power is "Acitvated" from the Hardware menu.
Thank you for using Fixya, an let me know if you have any additional questions.
1helpful
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
1helpful
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
1helpful
Onkyo Zone 2 Problem
Hi there
The only reference i could find to this in the manual is on page 55, in your hardware settings. It relates to the menu settings for remote control configuration/zone 2 activation. Do you have a user manual to help you here? Hit the link above and enter an email address and you can down load one. Good Luck, any dramas,feel free to comment back to me here and we can sort it out)
regards
Graeme
2answers
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
