Question about Hobart SR24-H Built-in Dishwasher
We have a SR 24 H and water sits on the bottom it
We have a SR 24 H and water sits on the bottom it won't drain and it seems to be getting higher
Posted by innkeeper874 on
GPEC
    New Friend:
  • 12 Answers
Sounds like your drain valve needs replacing. The drain valve is located just inside the front lower service panel. You can also locate it by following your drain hose back to it. The part is often white with a red solenoid on it. You can check the valve by putting a volt meter on the two leads going to this part and checking for power when the machine is in drain mode. If the valve gets power and still doesn't drain then it need replacing.
Regards
Posted on Apr 09, 2010
My dishwasher will run and seems to clean but the panel is flashing. There is water sitting at the bottom and the panel shows red. Not sure how yo reset.
Check the filter and if equipped check the float in the bottom of the washer itself. Some of these circuit board will go bad and still function to some degree, but check the simple things first
Jan 11, 2015 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch shx33a starts, fills, then stops. Drains OK when forced to end cycle.
I know this may sound very silly but i had the same problem with mine and all i had to do was pull it out a bit as the drainage pipe at the back was only slightly sqashed against the cupboard but it does matter
Sep 13, 2012 | Bosch 24 in. SHX33A05 Stainless Steel...
It isn't draining. There is dirty water sitting in the bottom of it. Tried to see if anything was blocking the drain but couldn't find anything.
Check the entire length of the drain hose from the washer bottom to the connection at the sink drain for kinks--you may need to pull the machine out of the cabinet part way to check. Make sure the hose passes over a point higher than the drain connection at the sink. If you have access to a wet/dry shop vacuum, remove the sink end and **** the water out. If nothing comes out, then there is an obstruction somewhere. Use the vacuum to **** the drain opening inside the washer.
Sep 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
This is a very good web site. Thx for pulling it
It is possible the check valve is sticking causing sour water to come back into the washer. The check valve is located where the drain line connects to the back of the dishwasher. Also make sure the drain line is higher than where the line connects to the drain under the sink. Most washing machines have a loop built into the line but it helps it to drain better when the line is higher. Try hooking the line to the top of the cabinet under the sink if possible.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Water sitting on the bottom of the dishwasher
disconnect it from you drain and put it into a bucket. Then start a program and then cancel it, the begining should start with a drain anyway. Then you will see if any water comes out. You can also take a shop vac after to get the water out to see if there is any stuck there.
Sgt 48
Apr 25, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Hobart SR24-H Built-in Dishwasher Logo
308 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
