My Rotel RA-935BX blows out the fuse on the power socket during operation, after repair the fuse, it is blow out as Rotel power on, what's wrong?
Posted by peiliangc on
Anonymous
    New Friend:
  • 27 Answers
It seems you have a short circuit in your unit. Further attempts at switching it on are not advisable as more damage will occur. Get it checked out by an electrician who can test from the plug for a short circuit.
Posted on Apr 09, 2010
I have a rotel amp model no is ra-313
I'm guessing you don't know for sure that it even needs fuses. They don't go out like they used to, as everything is controlled by a microprocessor(computer within your unit). I would suggest, that you, with the power plug pulled out, use an ohm meter to be sure that each fuse is shorted. If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Jul 30, 2014 | Rotel Audio Players & Recorders
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
I have an elesis RA 500 it blows the slow blow fuse when i plug it in .any ideas what is wrong?
hi there,
it sounds like the internal transformer has gone.
It's not user replaceable and will require you to take to an electronics store to be repaired.
SAME THING RECENTLY HAPPEN WITH ONE OF MY BITS OF KIT ...... for heavens sake don't just keep changing the fuse time and time again.
Jan 07, 2011 | Alesis RA300 Amplifier
The two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Jan 17, 2010 | Audio Players & Recorders
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Manual circuit diagram
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
Sep 20, 2009 | Rotel Audio Players & Recorders
KEEPS BLOWING SOUND FUSE
When you refer to the "sound fuses" are you referring to the speaker protection fuses or the power supply fuses?
Dan
Jan 14, 2009 | Audio Players & Recorders
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
303 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
