Question about Microwave Ovens
We have a faulty Micromark tea urn rated 1500
We havea faulty Micromark tea urn rated 1500 watts. We need a replacement overheat thermal sensor the Tea urn model number is MM 9827 and the thermostat has HF then model KSD20-3 market on it plus 130 in larger letters. Can you help. Micromark seems to have gone into administration. many thanks
Posted by r_nightingal on
Gerry Harvey
    Genius:
  • Microwave Ovens Master
  • 1,481 Answers
Try espares.co.uk..they may help..the130 may be the cut off temp in which case ant TOC would do provided that its the same dimentions
Posted on Apr 09, 2010
Anonymous
  • 4 Answers
Do you live in uk? i want the lid off mm9827 if you want to sell it for spares. let me know if interested i'll give you my email to contact me.
Posted on Jun 28, 2010
Microwave arching
faulty microwave module replace it
Apr 22, 2015 | Sharp R530EWT Countertop Microwave Oven...
R-820js wont heat
see this causes and fix it .God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Sharp R820JS 900 Watts Convection ...
Breville bdf deep fryer keeps tripping out /turning off have to push reset buttons to get it started again after having to wait 10 mins to reset
That sounds like either a faulty thermal trip, or a faulty overheating fryer.
Is it clean around the element because if not the heat will build up, much like the fur on a kettle and cause the element to overheat.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
My samsung convection microwave oven continuly beeps nd flashes E 2
You have a faulty temperature sensor.
Replace the temperature sensor.
Nov 08, 2010 | Samsung MT1088SB 1000 Watts Convection /...
No lights on front panel. When power is switched off and on it starts heating and will not switch off when off is pressed
I suspect youy havea faulty touch pad. Try replacing it
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
Microwave shuts off after 10 to 15 secs and does not heat up. Would the inverter or magnatron be faulty?
The following List of things would cause that, you can test each one till you find it or drop it at a service center...
-oven fuse
-thermal cutout
-door interlock switch or monitor switch
-thermal cutout
-fan jammed or faulty
-diode
-circuit board, triac or magnetron
let me lnow if you want any further instructions...
~chuck : testamonials appreciated!!!
Oct 31, 2009 | Panasonic NNT995SF Stainless steel 1250...
How to replace thermal fuse/flame sensor
GE JES 1358 WK 01 microwave:
I recently had the same problem with a "flame sensor, " aka "thermal switch." My microwave is a "throwaway" model, very few repair parts available. I didn't want to replace it, so I did a little bit of research into thermal switches. I actually found one that would replace it for about $5 (plus $5 shipping).
Mine uses a "bimetal" thermal switch. There are three kinds of bimetal thermal switches: automatic reset, manual reset, and "one time use." The really interesting thing is this: the "one time use" resets (!!!) if the ambient temperature is below 0 degrees C, or 32 F (freezing); or, in some cases, -31 C, or about -22 F.
I put my "dead" flame sensor in the -10 F part of the freezer for about 20 minutes...
Checked it with my multimeter, and the once-dead sensor now read continuity (zero ohms)!!!
Reinstalled it in the microwave, and now it works fine.
So if you have a dead sensor- try freezing it...
Sep 21, 2008 | Microwave Ovens
Microwave Ovens Logo
240 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
