Pls. check your ac compressor magnetic clutch attached in front of ur compressor if its working/ ac clutch engage when u turn the ac switch on and disengage when u turn the ac switch off/ it normally makes a clacking sound when it engage with the rotation of ur compressor/ if its not engaging it means ur magnetic clutch is stuck up giving excessive load to ur engine thats why it overheats/ it smell burnt because its magnetic coil is fried/ or check cooling system of ur car might be that coolant is empty/ fan is not working/ radiator is clogged or thermostatic valve is stuck blocking coolant flow....
