Question about DISH Network ViP 612
Skipping, feezing on recorded programs. third dvr. all same
We have had techs out twice. we now have our third dvr. all have same problem. tech said this unit has problems. no solution in sight. not really great answer. someone must know if this can be fixed or not and how. we are not getting a product that delivers recordings we are paying for. it seems to be a "shoot in the dark" approach when it comes to troubleshooting this problem. according to posts i have read, this is not an uncommon problem. last suggestion was to unplug the dvr from a surge protector. this did not solve the issue.
Posted by ttranbarger on
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
I am very sorry to hear you have continually experienced problems with your VIP 612 DVR receiver, a important question when considering what may be causing issues with the numerous receiver you have had is, are you fully powering off the receiver each & every night? If not I would recommend doing so, by powering off the receiver each night it allows the receiver to receive necessary updates and helps to prevent these types of DVR issues. Perhaps you may want to try this and seeing if it resolves the problem. Additionally, another recommendation I would like to make to hopefully help prevent further frustrations with the DISH Network DVR receiver, would be to delete older recordings you have already watched or may not need anymore, this can also help when trying to prevent & fix DVR problems.
I hope these tips resolve the issue or help to improve the DVR functioning. Please let us know if you need any further assistance.
-Kirstie DISH Network
Posted on Jan 30, 2011
Blown fuse cause
Hi Karen,
Since you said it was electrical issue that is why your DVR is not working anymore due to damage on its electrical component as well. You might wanna talk to them ( Tech Support Rep) to replace your DVR for free. Or you may want to go to nearest Comcast Store in your location to replace it for you. Former Comcast TEch here
Mar 03, 2014 | Comcast Televison & Video
I FORGET LOGIN PASSWORD OF "ZEN TECH DVR 36584 V
i have the same
ZEN TECH DVR 36584 V u can remove the battery and turn on the dvr but i cant log in i fogot the default password ....anyone rem it?
Aug 19, 2013 | Computers & Internet
Twice the heat went out LG 18000 5 year warranty. 1st time unit sparked inside the unit, Tech came out couldn't repair was given a new unit (2 weeks out of service) had to buy 2 floor heaters at a cost...
was the first unit a different model ? what the repairman said is pretty much right but they should be more ontime and communicate if they want a good name. the unit should work fine after replacing if it doesn't dont pay for the part
Nov 10, 2010 | LG LWHD1807HR Thru-Wall/Window Air...
622 rebooting problem
This issue would have to be resolved in home, it is linked to a power issue and your voltage will need to be checked at the outlet your recvr is plugged into, HD DVR's need alot of constant power to operate poperly. the nes time you call about this issue the standard procedure is to send a tech to check voltage.
Oct 03, 2009 | DISH Network ViP622 DVR DTV Receiver /...
It is 98 degrees outside, and my AC is only cooling the house to around 84 degrees I am so upset. It is a new unit about 2 years old, and I got a bigger unit than I used to have.  My old unit was...
Sounds like have charge problem. You need aservice tech to check this. Make sure you ask him to check the unit split. Which means the temp. of the air coming into your reurn or filer area and temp of the air at your closest outlet. The difference between these two is the split. Should be between 19 to 23 degrees if charge is right. If this is to low the problem may be a heat strip stuck in or the charge is off. Either way you need a good service tech you trust. Not all service techs are service techs period. Ask for a free estimate on checking your unit. If you put a bigger unit in your house it should be freezing you out. Russ
Jul 18, 2009 | Ruud UAKA048 Air Conditioner
Brand new dishnetwork 622 DVR UHF remote does not work
Contact Dish Network tech support. If they can not fix it for you over the phone then they will send you a free replacement. Hope this helps.
Apr 01, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Calls to tech support do no good
It is your motherboard, since sansa works from a flash, i doubt it could be the flash. if it is still under warranty then I suggest you take it back, if not then send it to my company and we can give you a good deal on a new motherboard to fix your problem. thank you, Connie
Jun 19, 2007 | SanDisk Sansa e250 MP3 Player
Yamaha dvr-c300 dvd playeer
Hi sponge your lens is the problem call a tech to look at your set.good luck.
Apr 26, 2007 | Yamaha DVR-S200 DVD Player
DISH Network ViP 612 Logo
411 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
