I have a broken nut on the pole of a Remington pole saw Its a plastic nut, how do I fix it?
RemingtonPower is no longer in production, The "Coupling Nut" was replaced by a "Thumb Latch" neither of these nor the entire pole assembly are available.
You might try this (no promises).
http://store.poolcenter.com/shared/StoreFront/product_detail.asp?RowID=167966&CS=poolcenter&All
Someone recommended using a hose clamp in place of the nut.
I think these are band-aids and eventually you will need a part that cannot be found.
We rarely get inquiries for McCulloch or Poulan electric units. Might be worth a look.
If you care to try on your own start here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Sometimes you can find NLA parts (use part number for above) offered here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
