Question about Philips 42PF7320A 42 in. Plasma HDTV
While watching tv half the screen goes black
Screen goes half black. Have to turn off tv for a period of time and then screen is full for about 30 min before going black again.
Posted by magpines on
Anonymous
    New Friend:
    Problem Solver:
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Posted on Apr 13, 2010
Darren Law
  • 131 Answers
Hi
Depending on which section of the screen goes black ( top or bottom ) this is down to your Y buffer boards, these with the back of your tv are on the very far left hand side ( long and rectangular in shape and connect to your screen.
Depending on top or bottom remove the one that is faulty and get the part number of it then Google or Ebay for a relpacement.
Hope this helps
Posted on Apr 09, 2010
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
2helpful
2answers
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any...
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
1helpful
Screen goes black
Check and make sure the software is updated on the set.
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
2helpful
2answers
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
4answers
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Philips 42PF7320A 42 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
