Kia sedona 2002
6 ignition coils, one for each cylinder. 3.5 SFI DOHC.
I think the coil pack has 2 in each, maybe one, but if it is a 6 cyl, then 3. They will be all together in a unit. I don't know this for sure, but it is a general thing. Hope this helps.
There are 3 coils, one sitting on top each of the front 3 spark plugs. When each of them fires, they also fire one of the plugs in the back. To access the back plugs and wires, remove the intake manifold. Google "replacing plug wires on Kia Sedona". If you suspect arcing, remove plastic cover from top of engine and view engin running at night with on lights on. Rev engine and look for arcing.
Read below please!
BTW...good job Tony Roc!
A 2002 Kia Sedona ex 3.5L v6 ONLY HAS 3 coil packs! They are all located on the front 3 cylinders. They are whats referred to as double coil packs. There is a ignition wire coming off each one of them, they circles around the back side of the engine and connects to spark plugs 4,5, and 6! With a code p0305 any one of them could be bad! Test each one or just replace them all!
Could you tell me what year the sedona is?
