Bosch LogiXX8 flashes F23 What does this mean and how do I get my washing out of locked door?
Posted by kris_gray on
mammonah
    New Friend:
  • 3 Answers
Means there's water in the base pan and you need to call service at Bosch who will give you a repair serivce in your area.
Posted on Aug 02, 2010
Anonymous
    New Friend:
  • 3 Answers
Take the clothes out and push the button on
Posted on Apr 09, 2010
F18 is flashing on a Bosch front loader washing machine ( Logixx8 Sensitive)?
If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Sep 10, 2017 | Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I have error message nr0 on my Bosch LogiXX8 What is wrong and how to mend?
It is the child lock. Turn machine on & then press & hold the start button for 5 second. Code will flash then disappear & machine will be back to normal.
Page 5 of instruction manual for more details
Oct 18, 2010 | Washing Machines
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
Bosch flashing F23 fault and door wont open tried to reset by manually draining and resetting power but no joy
this has just happened to my Bosch, means the base pan is leaking water...I've had 4 problems with mine in the past and WILL NOT BUY BOSCH AGAIN, poor customer service too.
Nov 19, 2009 | Bosch Logixx WFT 2806 Front Load...
Error code F 23
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
F23 fault
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@@@
Oct 25, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
1,075 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
