1995 Jaguar XJ6 Logo
Posted on Apr 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jx6,x300 erro Cod P1621p1621
I have a Jaguar jx6, X300 year of construction 1997.
sometimes with to start engine goes out.
I get error Cod P1621?
what cod is P1621?
can ignition coil be defkt?
Anonymous
Level 3:
  • Master 507 Answers
  • Posted on Apr 09, 2010
Anonymous
Master
Level 3:
Answers
507
Questions
Helped
212365
Points
1493
That code is for Engine control module engine immobilization input circuit malfunction. Ignition coil is ok.
2answers
Where is fuel pump relay on a 1995 jaguar x300 sovereign?
Repair your vehicle right away. Just click on the link I attached 1995 jaguar x300
Jaguar x300 4.0 soveriegn alarm siren location
under the left hand front wheel arch area,
2answers
Car won"t accelerate over 30 mi/hr, gas pedal pushes back on foot, if a bump is hit the car drives as normal
when you say turbo has someone fitted a aftermarket turbocharger ?or is it a xjr with supercharger? what model is it ? xj40 or x300, the only connection with the throttle pedal I can think of is the cruise control or the gearbox kickdown cable. all the xj40,s had a kick down cable, the 3.2 x300, also. the 4.0l x300 was electronic. start by checking the throttle cable, pedal, and throttle body. if it has a kick down cable try car with cable disconnected.this sounds a strange one, love to drive it have been a jag tech for 40 years
Hi! My friend has got a Jaguar xj6 1997 with a 3.2Litre engine and automatic transmission. It doesnt start. Went to work,worked just fine. Dead later on the same day. Battery ok. Tried jerking the...
i assume your car is@1997 a model/year x300 a common cause of the symptom you have is a corroded/open circuit wiring at a connector or around under the washer bottle filler white connector i think its the ok to start signal from the security/locking module located below trunk fuse box the module can also go faulty. one easy test is to switch ign on if the check engine light goes off with other warning lights. start there fault finding with the wiring etc
5helpful
3answers
1997 Jaguar XJ6 will not start. new battery still wont start, good stater. what do i check now
crank relay on the front pulley or ignition module under the coil ,it has to one or the other
1helpful
Daimler Double six - Wheel nut torque wrench setting Uses the chassis from Jaguar X300 Built 1997
68-88nm Steel Wheel 88-102nm Alloy Wheel Figures represented as printed in manual.
--- This is for Jaguar XJ12, Also badged Double Six - sure its the exact same car, its built 1997-1997 its a 6 Litre V12,
Jaguar x300 no pulse at injectors replaced ecu, what else could i
does it have a spark at the spark plug leads? if no it sounds like the crank shaft sensor!!
2answers
Jag x300 3.2sport 1997
Hi t  need to read the codes for the light, might be anything
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
