Canon MP-11DX Calculator Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting date and time, I put in correct date but doesn't stick ,
[email protected]
Anonymous
Level 2:
  • Expert 45 Answers
  • Posted on Apr 10, 2010
Anonymous
Expert
Level 2:
Answers
45
Questions
0
Helped
61256
Points
244
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
I cannot get the correct time on my firestick.. ive gone into settings, time zone , added correct zip code and it still gives me the wrong time if i ask what time is it
hi Cjjalbert.
this is all i could find out.
How to change date and time on fire stick? To change the time zone:
  1. Swipe down from the top of the screen and then tap Settings.
  2. Tap Device Options and then tap Date & Time.
  3. If Automatic Time Zone is turned On, your device will use a Wi-Fi or Mobile network (if available for the device) to determine the time zone
Change the Date and Time
or try this link.
how to the correct time on firestick Google Search
Where is OK button when setting date and time
Correct my date and time to update my phone ' Windows ...
www.windowsphone.com/.../correct-your-date-and-time...
Windows PhoneIf you're having trouble installing a Windows Phone update, correct your date and time settings manually.
How to Change the Date in Android ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
Android phones normally pull the date and time from the Internet, but if there's a problem with the signal ... Click the "Settings" button to open the Settings menu.
2013 Models - How to Set the Date and Time on your ...
? 0:52
https://www.youtube.com/watch?v=jTSZwCLSiTk
Dec 4, 2012 - Uploaded by Panasonic Canada Help
In this video we will explain how to Set the Date and Time on your Panasonic Cordless telephone, models KX ...
How to Set the Date and Time on Your iPhone - For Dummies
1helpful
4answers
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
1helpful
2answers
My pantech all of a sudden has the wrong date and time on it how do I correct it ?
Go to settings then cliq on time and date settings, then set it to the normal time then cliq OK. Thank you for using Fixya.
The day date always now switches over at noon instead of midnight. I've tried to reset it correctly several times, but it doesn't work. what do I need to do?
Hi!
The problem you described is caused by incorrect setting of the hour: AM and PM must be set correctly, AM before noon and PM afternoon.
For more details regarding setting of your watch, please visit Citizen site here:
http://www.citizenwatch.com/COA/English/settings.asp
Please let me know if it helped,
good luck!
4helpful
Every time I want to take a picture, I have to set the date or it goes back to 01-01-80. I replaced the (date) battery with CR1220 as instructed and put in the correct date. When I shut it off and turn...
Ah-h-h, January 1, 1980....I remember that day. Whoops, I started to slip away!. Try pressing menu/set twice after you set the date and see if it sticks around this time.
1helpful
How do i change the TIME on my Marquette ECG machine?
setup, time date then type in the correct info. Make sure you use the correct "separator" for the time and date. You need to put in the ":" for time and the "\" for date or whatever your system calls for. If it keeps on loosing time and date settings you will need to replace the quarter sized lithium ion battery that holds this info.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
Jun 24, 2010 • Medical
2answers
Sony dsc-s90
Many digital cameras have a 2nd disposable battery to remember settings like date and time, and where to put the pictures, when the rechargeable battery is removed,, but I don't believe that is the case with your camera. possibly you are not actually getting the time set correctly, since the camera will continue to ask for time & date setting every time the camera starts, if it is not set properly when it asks. Concerning internal memory- Can you transfer the images from internal memory to the memory sick when you do insert it, or is there a chance that the memory stick is defective, and therefore the camera doesn't record to it?
4helpful
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
38helpful
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
old marine
old marine
ZJ Limited
ZJ Limited
