Question about TechnoMarine Watches
Hello, are there screw down crowns replacements for technomarine? mine fell off. Where can I find a replacement?
Posted by titomantica on
Anonymous
    New Friend:
I too am looking for replacement screw down crowns...were you able to find them?
Posted on Nov 09, 2010
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 | Watches
Does the crown on the 609001 Technomarine have to be screwed in after the watch or date is set?
Yes, you must always screw down the crown. If not, you will get dirt, sweat, water inside and it will cost alot of money to repair
Jun 15, 2011 | TechnoMarine UF6 Lady Silicone Strap...
Just bought a technomarine watch and can't pull out stem to set time and date
Sometimes the crown is screwed in to help keep it water tight. Turn the stem anti-clockwise to see if it will release "give several turns" if that fails return it for exchange.
Dec 31, 2010 | TechnoMarine CSX01 Wrist Watch
I have a Techno Marine diving watch. It just stopped. How do I best replace the battery. Myself? Or do I need to send it somewhere? Cebron
Thank you for contacting FixYa.
NEVER attempt to replace a battery on a diving watch yourself. It will break the seal.
You will need to send back to Technomarine or take to a registered Technomarine service center.
You can find information here:
http://www.technomarine.com/Customer/Services.sls
Best regards! Jewel
Oct 05, 2010 | TechnoMarine RSQC11 Wrist Watch
Hello i recently bought a technomarine watch and it is not moving. what do I have to do?
If you bought it recently, bring it back to the place you bought it from and ask for replacement.
Aug 05, 2010 | TechnoMarine DTC55C (Size: Unisex Adult)...
Hello, my new Tagheuer aquaracer calibre 5 500m
I have the same problem with mine....They have some kind of manufacturer malfunction , tag will not admit. My is in the shop for the 3rd time ...at this point they should replace my watch...this one is a lemon.
Jul 28, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Screw down crown wont screw down
Either the crown or the case tube threads are stripped. Which ever part is stripped needs to be replaced. Keep in mind that both could be the problem. Be sure you don't get your watch wet until this is fixed. Your watch is NOT sealed for water resistance if the crown does not screw down.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Mar 22, 2009 | TechnoMarine Ceramique Watch TCB02C
Watches Logo
252 people viewed this question
Top TechnoMarine Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
john h
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
