Question about Hammers Air Gun Rifle Scope 3-7x20 With Rings
How to use the BDC on my rifle scope
Can you tell me how the BDC works on the 3-9x42gdt Hammers Rifle scope. I know it is for the 223 but not sure what grain bullet.
Thank you in advance
Leon
Posted by twinbard on
Ned White
  • 2,100 Answers
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. NikonHow to use the BDC on my rifle scope - 2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Posted on May 04, 2010
My 308 winchester semi automatic rifle jams after shooting first bullet. In order to recover, you remove the clip, eject the bullet, replace the clip, **** the rifle and shoot second shot jams
no
there is a small lip that pulls the shell out of the breach as the bolt moves back
take it in to a firearm repair shop and have it properly fixed
Oct 05, 2016 | The Optics
Loading data for leverevolution bullets in a Winchester 94 rifle?
Here are some basic .30-30 specifications of interest to handloaders: bullet diameter .307-.308", maximum COL 2.455", maximum case length 2.039", MAP 38,000 cup.
Medium burning rate rifle powders work best in the .30-30 with bullets in the popular 150-170 grain weight range. Examples of popular powders include IMR 3031, IMR 4895, H335, H4895, RL-15, and W748. For decades I have used IMR 3031 behind the 150 grain Speer or 150 grain Sierra Flat Point bullets and CCI or Winchester primers with excellent results.
The Hodgdon Data Manual No. 26 shows that 31.0 grains of IMR 3031 powder will drive a 150 grain bullet to a MV of 2184 fps, and 33.0 grains of IMR 3031 will drive a 150 grain bullet to a MV of 2364 fps.
The same source shows that 30.0 grains of H4895 powder will give a 170 grain bullet a MV of 1919 fps, and 32.0 grains of H4895 will give the 170 bullet a MV of 2212 fps.
An unusual load with very low recoil that is excellent for plinking and small game or varmint hunting with a .30-30 rifle is a 100 grain bullet in front of 15.0 grains of SR 4759 powder for a MV of 1834 fps, or 18.0 grains of SR 4759 for a MV of 2034 fps. These loads give excellent accuracy in my Winchester Model 94.
Mar 26, 2015 | Winchester Optics
What kind of scope would be good for my 308 axis rifle?
Redfield and Vortex brands make good entry level scopes with good clarity, durability, features and warranties. If you plan on hunting a scope with a low power around 3-4x and a high power of 9-12x with a bullet drop reticle like the Vortex BDC would be a good choice.
Jan 10, 2015 | Optics
Have a Tasco 6-24X40MM BDC scope and need the chart for the interchangable BDC tarrets.
I have the chart for the TR624X40MM BDC rifle scope. Send me an e-mail to [email protected] with your e-mail address or fax number and I can send you a copy.
Dec 08, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Once zeroed in is the range on the turrets correct at i go longer distances?
This depends entirely on what class of cartridges the scope was built for. Different cartridges will drop more or less at a specified distances based on starting speed and ballistic coefficient. If your scope is built for a .223 and you are shooting a .223, then it will work fine. If you mounted it on a 45-70 however, the bullet will drop much more quickly and your necessary scope adjustments will not match the markings on your scope.
Oct 10, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
When adjusting for a couple of inches, the next shot is a foot off. It seems to wander all over the target.
! click is 1 inch @ 100 yards, provided you have the correct scope for the rifle.
If you are sighting in a .22 LR 40 grain match velocity bullet for 100 yards, the mid range trajectory (50 Yards) is 6" higher. The bullet has a 6" arc half way to your target. If you are sighting in a .270 with 150 grain blunt tail bullets for 250 yards, the mid range trajectory is .4 higher. It only has 4/10" arc half way.
You most match the scope to the gun, and the 1 click= 1 inch rule will apply. Otherwise, it's lock it into a righd mount, fire it and adjust the scope accordingly. If you want to change the range on the scope, it will be guesswork.
I use a Bushnell Banner 3-9X40 with BDC. If you have BDC, make sure you have the correct distance ring in for the caliber.. It will make all the difference in the world.
Oct 27, 2009 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Muzzeloader won't fire ,new nipple,caps fire,nothing is pluggedl.
its not a bullet problem you can shoot that out of your hawken muzzeloader your problim is getting the pan powder to ignight your powder in the barrel you need to make shure powder never got damp now on your hawken you have a removable torch hole were the pan powder lays take that out and just drill the hole out bigger not much just a little bigger in the part you took out this will make your hawken fire without any problem i have done this to many hawken rifles and its like night and day how it fires hope this helped ya out and good luck
Dec 11, 2008 | Thomson Thompson Center Muzzleloader Rifle...
Hammers Air Gun Rifle Scope 3-7x20 With Rings Logo
1,572 people viewed this question
Top Hammers Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Hammers Optic Expert? Answer questions, earn points and help others
