Smeared output can result when you refeed a printed page into the
printer to make a double-sided page. This happens because the
rubber
rollers that grip the paper to pull it into the printer can pick
up toner
from the first side’s printing and smear it. So before replacing
parts, this is an easy thing to check. Printing multiple pages consecutively
will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner
also happens because the nonstick coating on the
fusing roller is scratched or has baked-on debris. This can happen
if the printer is in a dirty environment especially. If you are
comfortable removing the fuser, you can try to
clean it
with a soft cloth and alcohol, but make sure you let it cool down
first!
Finally, if this does not resolve your issue then make sure the fuser is
heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to
replace the entire fuser assembly. This will be pretty expensive to
repair so hopefully it's one of those other issues.
