Hello. To give a more precise instruction, I would need to know the watch model. But the standard procedure to set analog time would be to pull that little pin on the side of the watch, and than turn it. You should see the handles turn accordingly. Notice that the pin may have two different "heights", one for adjusting time, and one for adjusting the date. Let me know if that solved it!
No, we are NOT a store. THis is a community of consumers (like you).
If its just a pin you need, I would find a local watchmaker who should have most pins in stock. If this is not available, then you can try to contact DKNY at the following link, but you will have to be able to be specific with info about your watch (you will need to give them the info on the back of the watch)
Best regards!
The best advice I can offer you is this.
Setting the Watch
Pull on the watch's knob, located on the right side of the face. It will pop out to a wider setting, one notch outward. This notch is the hour and minute setting for your watch. Turn the knob to move the hour hand, and set the proper time. Press in on the knob, against the spring, until you feel it hit the base. Wait to verify that your second hand begins moving, indicating that your watch is keeping the correct time.
On digital watches, press and hold the top button until the time begins flashing. Use the bottom button to move the hour and minute. Press the top button again to replace the new time and set your watch.
Repairs and Service
Keep your receipt and warranty paperwork in a safe location. This documentation will be important for repairs, resale and service. Visit your closest Diesel store for repairs requiring mechanical adjustments--or a trusted jeweler can handle the maintenance such as wristband alterations. Note that your Diesel watch may use links, held in place by small pins. These pins are best removed and adjusted by a jeweler or watch technician, so as not to damage the quality and value of your watch.
mcdevito75 here, That pin is called a spring bar and is used to hold the band to the watch, the pin must be frozen in place on the watch, Best Bet is to try another jewelery shop, in the meantime you can put a drop or 2 of cooking oil on the pin just as it meets the watch this may loosen the remaining portion of pin.
You have to visit any of nearest watch repair shops and watchmaker will do the job for you.All decent watchmakers can repair very many different watch makes,so, no need to find a particular Columbia watch repairer.Type in your browser:WATCH REPAIRS IN (NAME OF YOUR TOWN), and you will find quite a lot watch repair shops. Rate me, plz.
dont do anything!the watch needs service.perhaps somehow the watch fallen in a hard surface and something moved or broke in the balance wheel.the hairspring the pallet or the wheel have serious damage.to have your watch healthy wateresistance and accurate try to find a seiko authorized service center to repair your watch!
That's right, nothing will hold that button in place as clipspring has fallen off or broke and retains inside the watch. Do not wind or wear your watch now as that clipspring is freely floating inside movement and can damage your watch geartrain. Find your nearest watch repair shop and ask to refit button with clipspring. Watchmaker will know how to do the job and how to get rid of any broken remains if there are any. Don't forget to rate, please.
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS. Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button. Use small steal pin to push these buttons. If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault. Rating is very appreciated.
