Frigidaire side by side mod # FR26ZSHB5 The condenser fan not getting voltage 110v - Is there a In- line fuse link / fan works by suppling ac to it .
My water suppy sprayed water over a long time to the botton of unit is what cause the fan to get wet ( cheap plastic line ) I'm missing the voltage to the molex plug to operate the fan.
Thanks for your help.
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
SOURCE: WHAT IS PLASTIC COIL OF TUBING IN REFRIGERATOR BEHIND VEG DRAWER?
that is the water line that goes out to your water dispenser. it is placed there so that the water that would come out is cold. as if it is the water reservoir.
tnx 4 using fixya,
drcool
SOURCE: Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the
ice buildup is allowing conductive cooling into the refrigerator
section and therefore is allowing condensation on the refrigerator wall
or ceiling.
4 The refg section has a heater (possibly not positive) in the area of
the door frame, or it may have a "power saver" switch. This switch and
the heater (if it has a heater it may not have a switch) are designed
to stop condensation on the refridg while running. I fit is placed in
the "power save" mode it turns off the heater. But, if you live in
extream humidity (Great lakes east side or Gulf coats Houstion...) the
humid air will condensate water out and it will collect and settle on
the floor.
5 Door gaskets are not sealing especially on the bottom of the door.
This allows warmer air into the fridge section and it is condensation
on floor under the crisper.
If you check all of these items and still cant find it please post back
and tell me what you did find. So I can help you more. Please rate me
as much as possible as Im trying to keep my average up and do the
things that will actually educate and help people.
THANK you for using fixya and good luck..
SOURCE: Frigidaire fridge side by side not cooling after cleaning fan
Sounds like you have a bad compressor
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
