Question about Samsung HLR6178W 61" HDTV
Burned out lamp?
The television was on, and suddenly made a loud popping sound and the screen went black. Now, when in stand-by, the power button flashes all three messages, Timer, Lamp and Standby/Temp. When turned on, it makes a small buzzing noise, Lamp continues to flash, but no picture comes up.
Posted by theoneisenta on
Cary Leonardt
  • 304 Answers
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Posted on Apr 14, 2010
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
It went pop screen went black no power serge
If you heard a popping sound chances are your lamp went out on you.You can purchase a quality replacement lamp at discount-merchant.com
Apr 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
Loud pop from projection TV, then no screen
Ur power board it dead.Replaced capacitors that puff up or pop open.Or replaced the whole board.
Dec 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Was watching the tv and heared a small pop in right rear of unit. screen went black and a split second later the sound went. now just get the green flash on power button.
Don't know what brand or model but sounds like you have a dlp set and the lamp blew, replace the lamp and should be ok.
Dec 03, 2009 | Televison & Video
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
Heard a pop and screen went black
Sorry thats the death of your tv I
m afraid, the pop you heard is either your lamp or tube going boom.
Apr 03, 2009 | Televison & Video
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR6178W 61" HDTV Logo
222 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
