Computers & Internet Logo
Question about Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW
I cant change my color quality on the properties
Posted by loveu4ever28 on
Anonymous
    New Friend:
  • 38 Answers
You need new drivers or it is something wrong with os....
Posted on Apr 09, 2010
2helpful
2answers
Cant print in color with e studio 281c I can copy in color
The 281c can be set to print to black only as a cost saving measure. The printer control panel is accessed through your browser (using the IP address of the printer) and the setting is made there. You should be able to override this through the printer properties in windows, but I have found that the PCL5 driver worked to switch between B/W and colour, while the PCL6 driver did not. So, for me the easy solution was to install the PCL5 driver and use that.
Color in printed pictures is terrible! All HP
try going into your printers properties and look for a print quality tab. One of the tabs will allow you to change your print style on pictures. Or the HP software that came with the printer should allow you to modify the print quality.
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
2helpful
2answers
My Hp 1401 or 1400 all in one printer's software will not work on my new vista computer. I somehow changed the color to print a black and white photo, can't remember how I done it. Now everything prints...
  1. If you need to change settings, click the button that opens the Properties dialog box. Depending on the software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  2. Select the appropriate options for the print job by using the features available in the Paper/Quality, Finishing, Effects, Basics, and Color tabs. (Color Tab should allow you to change from only Black printing)
  3. Click OK to close the Properties dialog box.
Hi,Have 710n when powered up shows "not optium mode" box and cant get into menu.How do you access menu? Many Thanks Bruce
In Your Desktop, Right Click -> Properties. In this Display Properties window, Click on Settings Tab.
Adjust the screen resolution to '1280 by 1024 pixels'.
Set Color Quality to 'Medium (16 bit)'
Then click on 'Advanced' Button. In Monitor Tab, Set the Screen Refresh rate to 60 Hertz. Click Apply/Ok in both the settings windows. This will Solve your Problem. Else, Try setting Color Quality to 'Highest (32 bit)'.
2answers
My computer says i need to change my color depth, how do i do so?
You can change the color depth by right clicking on the desktop, click on properties, click on settings. You will see something as color quality, you can change it, thats also known as color depth.
Regards,
Shrey
2answers
Printing grayscale
in MS office you change pictures 's colour and print them in garyscale go to picture tool bar and change its colour and in printing prefrence from printer properties change dpi setting to save ink
My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
The screen on my hp laptop is loose, how can I tight it?
right click on the desktop, from the context menu choose properties and display properties window will display, choose the setting tab and change the screen resolution and color quality that suits ur eyes and ur pc
The picture on the screen as all fuzzy and cant get a clear picture without having a shadow or it being fuzzy
Do you have a led or crt display? It could be just your display settings. Go to control panel /display properties /setting tab / and try changing the screen resolution. If no difference try the color quality. You can change the color bits without hurting any thing. Just remember what you changed it from and to.
If this doesn't help maybe you'll need a new screen.
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
