The center channel on my STR-DE575 is not working. Is there a part that I can buy and repair it with?
First of all check that it has not got switched off somehow. After that, what I would do is trace the wires back (inside the unit) from the center speaker connector. This will take you back to the output semi-conductors for that channel. I would suspect these first, you might even see damage! You should anyway be able to look the numbers up on the net. If they are cheap I would replace them anyway. If that doesn't work I suggest you hunt down the service manual, it might have suggestions in it.
