I have a Balance Digital Technology flat panel monitor and it recently started blinking green, and yellow alternately, when being refreshed out of 'sleep' mode. It does this at times for a very long time, sometimes up to a minute or more, before it jumps back visible (the screen). Also, even more recently, I have to constantly switch the power plug to a new outlet because it will simply go out, black screen, no power, no lights. I have no other problems on these outlets with anything else, only the monitor. But it is doing this more and more frequently.
Hello
before telling you the problem , check whether the cord into the cpu is not loose.if it is , then re-insert tightly, but if the connections are fine , i am afraid there is a bad news for you.
This is a failure in the
active matrix or its driver i.c. If the unit is out of warranty the
cost should be between $80.00 and $180.00 to fix this depending if the
active matrix is the cause.Call your costumer support as they only can replace this component
Hope your Monitor is in guarantee period and
Good luck
Thanks for your help!
