When you bought the Voyager, you should have gotten a USB cable to connect the Voyager to a computer. If not, you'll need to purchase one. NOTE: the USB cable needed has a standard USB connector on one end, but the other connector has to fit the Voyager (same place the charger plugs in at). Verizon sells the USB cords for the Voyager.
Your other choice is to get a MicroSD memory card, put it in the Voyager (place on the side to insert it), then put your music on pictures on the card, then take out the card and put it in your computers memory card reader, if it has one.
I have heard that some bluetooth will not pair with every phone but I don't know how true that is. I will check in 2 that and get back 2 u. I had a hard time pairing my bluetooth with my voyager I had 2 put both the phone and the bluetooth in discovery mode. I had to hold the power button on my bluetooth for about 30 sec till it went into discovery mode.
the other solution is not what i think they are asking. there are many ways to put the phone on vibrate: 1. closed: press the phone icon and hold the # sign. 2. open: hold down the Z key from the main screen. 3. open or closed: press the down volume key on the left side of the phone until it says vibrate.
Something similar happened to mine. It worked for 2 months, and my phone received a message from jabra to reset pass key. It did not accept, and it stopped working with my phone. I tried everything. I was told to hold the power down for 10 seconds to place in pairing mode, that did not work. This did. Hold the volume up down and the answer button down at the same time for 7 seconds. You have to make sure they are all down or it will not work. You will see that the light will stay lit continuously. This means it is in pairing mode. Then place the bluetooth on your phone on. Tap find device at the top. It will then locate the jabra. Follow any other prompts. If it asks for a passkey, or code, 0000 will suffice. Hope this helps. I looked for almost an hour and a half for the answer.
The LG Voyager does not have a fave five option. You can have a speed dial option. To setup speed dial , open the phone, hit menu, go to contacts, speed dials, click on a number, and then go to the contact you want to select for this number. To use this feature, you just have to press the number that person is assigned to and then press send.
Hope this helped.
