Question about HP LaserJet P3005 Printer
Hp laser jet p3005 printer when switched on it shows no display and it doesnt print also
Posted by sandycc6633 on
Walid M Sayed
    Sergeant:
  • 313 Answers
Check ypur power cable or you may have a problem in your formatter board,
Posted on Apr 08, 2010
When I initiate a print job on my HP P3005 laser printer it makes a roaring sound and then I get a error 52. I have read its the fuser and then I read its the laser scanner. Which one is it? Tom
Error 50.x related to fuser &52 for laser scanner assm.
For tec guys only: Open laser scanner assembly, remove laser scanner motor rotor, lubricate the shaft fix it back. (dont do this job with bare hands) check best of luck
Sep 21, 2011 | HP LaserJet P3005 Printer
I have a HP Laser Jet P3005. Change cartridge and now just printing out black pages. Put the old cartridge back in and it's fine.
Put the new one back in the printer. Try printing again. If pages are all black,
Take the new cartridge back where you got it and exchange it for another. It's a bad cartridge.
Good troubleshooting!
Apr 11, 2011 | Office Equipment & Supplies
The printer make noise while it is printing
Hewlett Packard P3005 Fuser
Its all about the gears in the fuser drive assembly and the bushing in the fuser.
The HP P3005 fuser is located at the back of the printer.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Feb 23, 2011 | HP Laser Jet Printer P3005dn
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
417 people viewed this question
Ekse
efs_perpends
efs_perpends
