Computers & Internet Logo
Question about Cadkey Corp CADKEY Version 6
Error accessing invalid language directory when opening cadkey
Posted by karen_radcli on
pwyman
    New Friend:
  • 3 Answers
I got the invalid language error recently rescuing a copy of CADKEY 19 from an old WIndows 2k server for an engineer where I work.
I eventually was able to get rid of the error message by searching for the string CK19 in regedit and altering keys with invalid paths to them from the previous install.
CADKEY 19 seems to store a lot of static paths in the Windows registry, I had to update at least a dozen or so.
Using the Find Next feature with regedit made finding the keys and updating them purty easy.
Posted on Sep 22, 2011
  • Anonymous May 08, 2012
    I recently got the Invalid Language Error. Here is what I did, cannot tell you which fixed it but it is working now. Installed first time with Custom Install and turned off everything except Program files. This was my original Intention. Bare Bones install.I then got the error. 1.) I created a folder under C:\Cadkey99 called English. 2.)I reran the install as Compact Installation. My guess is that the install fails to create the English Folder, then it fails to put files there. I think by manually creating the folder, the second pass at the install, then has a place to put the files and it works. Hope this helps, Good Luck to all you Old School Cadkey users!!
2answers
Does cadkey 19 run in windows 8
Yes, it does! So far I've run it on every MS ISO but 10. It look like thats going to be possible too. I have Cadkey 19 full. Every thing works. See me on GrabCad.com search Rob Hart. All drawn on Cadkey 19 and rendered with the latest veiwer.
Error accessing valid language directory
3helpful
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
D:\ directory name invalid message
that error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
13helpful
2answers
CADKEY 97
I had a similar problem trying to run under Windows XP and 2000 Pro.
I deleted the file named opengl32.dll from the Cadkey directory and now everything works fine.
By the way, Cadkey would load up and it seemed to be OK until I needed to type anything in, then it would make a warning sound and ignored the key strokes.
I hope this helps and works for you.
Top Cadkey Corp Computers & Internet Experts
Marvin
Marvin
Are you a Cadkey Corp Computer and Internet Expert? Answer questions, earn points and help others
