I have a sony ericson w910 si 1200-9797 that turned off and wont turn back on.when i charge it a red light appears above the green handset but the phone still dont turn on any help guys?
If it is NOT TURNING ON,.. PLEASE try:
1.Go to PC companion -> Sony Update Service and select phone update without connecting your phone.
2. Select your device and download the update (DONOT CONNECT PHONE)
3. When the download completes it will prompt for connecting you phone.
4. Before that phone must be switched OFF (donot turn on).
JUST PRESS DOWN THE VOLUME DOWN KEY AND CONNECT THE USB CABLE.
5. The Phone's LED will glow green and the update for phone will start.
6. After the update completes you will get the phone as an fresh new Operating System.
(WARNING - YOU WILL LOOSE ALL YOUR DATAS AND GET A FRESH START)
do you know anyone that uses a Sony Erricson Xperia X10 phone? If yes, borrow the battery and test it with your phone. If your phone turns on with the borrowed battery, then this confirms that it's a charging problem.
Read my tip on the below link, to diagnose and solve the problem.
The red blinking light is typically the result of a heating issue but can also be caused by both a malfunctioning hard drive or a lose connection. The big problem with this is the $150 price tag that Sony charges to fix the issue. Below is a link with a more detailed description of the issue.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
