Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Samsung hln617w dlp tv won't turn on.Makes a five note musical bleep, fans come on and lamp light blinks, but shuts down after 30 seconds. Does this three times before all three idicator lights blink with temp light being red. Cleaned out dust, replaced lamp with one I had bought before. Nothing!!
  • Anonymous Apr 11, 2010
    More info- Before this happened the picture froze in gray colors. Also wouldn't I hear a clicking if the ballast was bad and trying to start the lamp? I hope your right though!! Thanks for your info.
Anonymous
    New Friend:
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
  • Stan Lee
    Stan Lee Jan 03, 2011
    so -- "this was the cause of all your problems". WHAT was? and how DO you test to see if the color wheel is turning without the lamp installed...
    Stan
    [email protected]
Chi Chu
  • Samsung Master
  • 8,457 Answers
Ur ballast it dead,need it replaced too.Beside the bulb.Sometime,must replaced picture bulb and ballast together.
Posted on Apr 11, 2010
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
1helpful
Samsung hln617w won't turn on fans run lamp and temp light go on
Projection TVs require special knowledge and tools to diagnose and repair issues. You will need to take it to a TV repair center.
1helpful
2 different brands and models listed here--for the Samsung inspect to see if color wheel is intact and not shattered---have to remove the lamp to see it.
3helpful
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Samsung HLN617W No Sound. As I turn on the TV, the speakers give off a "sputtering" noise that can barely be heard. After a while the speakers come on. But, what used to take five minutes (2...
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
2helpful
Samsung dlp tv makes loud noise when turned on. Previously it was turning itself off.
Bad Color Wheel, Located Right Behind Lamp when you remove Lamp you will see the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
PN# BP96-00250A Price $82.66
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
2helpful
My HLN617W dlp will turn on with no picture (sound is OK), then will seem to turn off, then back on again without me doing anything. After this ritual being repeated, the lamp and power lights will start...
The lamp is finished. Order a new lamp using the code on the side of the TV. Remove the lamp door on the back of the TV (4 screws) and then remove the lamp (1 screw). Have a look at the lamp... is it damaged? See my tips & tricks if you want to learn more about the lamp.
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
2answers
TV SAMSUNG 61 IN. HLN617W
Sounds like it is overheating. It has a sensor that monitors light engine temp and causes a shutdown. Possible causes are:
- dirty ventilation fan filters.
- cheap lamp that makes too much heat
- faulty temp sensor (I don't think this model is known for this)
Samsung HLN617W 61" Rear Projection HDTV Logo
Ekse
Demonic-2011
Demonic-2011
