Question about Sony Ericsson Walkman® W610i Cellular Phone
I connect it and it appers charging-non-standard-battery
I connect it and it appears instead of optimized charge, it appear charging-non-standard-battery and it doesn't charge
Posted by dannypicado on
Anonymous
    New Friend:
  • 56 Answers
Off the phone 4 some time and on it then charge,if no change, change ur charger if nothing happen change ur battery or check ur charging port
Posted on Apr 07, 2010
tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 • Computers & Internet
2answers
Not charging
Hello My Dear Friend::::::::::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
1helpful
The battery isn't charging
First Option:
3helpful
My k550i shows, 'charging alien battery' some times i'm connecting to plug, some times it shows 'optimized charging'. wats d difference between these 2 messages.
The battery you are using is not of good quality.Alien battery actually is categorized as the lowest quality of compatible batteries, Optimized Charging refers to the advanced charging circuit in SE phones that prevents damage and ensures the battery is properly charged.
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 • Cameras
1helpful
Sony ericsson w800i
no there isn't something wrong with your battery.There also isn't anything wrong with your charger. You have to take your phone back to the shop,this happens with most of these phones.
3answers
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
3answers
3answers
Sony Ericsson Walkman® W610i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
