Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
This happened to me today too. I heard an intermittent beep (I thought it was some kind of "hot" alarm). Then the 2 hobs on the right stopped working. Looking at my consumer unit, the fuses didn't trip so I'm not sure what might have happened
Is that beep very anoying? If it's just an occasional beep and you don't have a manual to check why it beeps, let it beep, No harm is done You can look for a manual af manuafacturer's website. Contact them and maybe the'll send you one, for a fee. You also can ask them why your device beeps occasioanlly
That's the low battery voltage indicator. Make sure there is enough battery power to run it. Anything lower that 10 volts will trigger the beeping and turn off the unit.
pls check your users manual may be your ref. has a door sensor that if is open intermitently it is beep but theres no problem with the operation with regards to cooling thus means your ref is normal. try to reset by unplug your unit and after several minutes plug yuor unit then observe.
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated).
