Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
My dishwasher will not fill all the way, only partially.
D. Floyd Kolb
  • Haier Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 07, 2010
Anonymous
    New Friend:
My haier dishwasher is filling a little then stops and bleeps ten times,i have tried tilting it,it is doing the same again,what can i do
Posted on Apr 09, 2011
1 Related Answer
Anonymous
SOURCE: Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
Posted on Feb 08, 2009
The dishwasher is not completely filling with water - is there a filter that should be cleaned to allow a complete fill
Yes, you need to turn off the water supply, and disconnect the hose (or copper tubing) where it goes into the dishwasher (the input to the water valve). There is a filter screen right there that can get clogged with debris. Clean that out, and you should be fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 20, 2014 | Frigidaire Dishwashers
Srs55l22 is not filling with water?
check water going in the machine and check water valve with ohms meter. also if its partially filling it can be the circulation pump. check these things in that order.
Feb 28, 2010 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
Not filling with enough water only filling partway
The fill cycle is a set time and not measured. Either your water pressure is low at the dishwasher or the screen on the fill valve is partially blocked keeping the correct amount of water from entering during the fill cycle.
Eric
Jan 11, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
Not enough water is dispensed during fill cycle. This causes top washer not to have enough water volume to move top washer wand.
First check that the fill float switch is working.
Next that the fill valve doesn't have crud that limits water flow. They MAY have a timeout to prevent overfilling if fill is too slow and that could cause the priblem if fill valve is partially blocked.
Aug 10, 2009 | Kenmore Dishwashers
May 31, 2008 | Jenn-Air 24 in. DW961 Built-in Dishwasher
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
330 people viewed this question
Top Haier Dishwashers Experts
Marvin
Marvin
Peter
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
