RCA D52W23 52" HDTV CRT TV Logo
Question about RCA D52W23 52" HDTV CRT TV
How do I access RCA HDTV D52W23 Service Menu?
How do I access the Service Menu so I can adjust the convergence?
Posted by Bengjie on
Anonymous
    New Friend:
  • 21 Answers
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Posted on May 26, 2010
Do you know the code to overwrite or adjust my d52w23 model type tv?
Thats the ITC222 rear projection you can change settings and defaults via of the internal service menu. But its not advisable to do so unless you have the information which lets you know how and what to adjust as some settings can prevent the set from powering up or operating normally unless they are restored to the default settings. I suggest getting the manual which explains the proceedures. You can get one at the following link its the ITC222 Convergence and Geometry CD its available by download link.
http://www.tvrepairworld.com/instructional_cds
1helpful
The convergance menue is gone. I need to adjust the convergance badly but it is no longer in the menu
You need to resolder the flyback transformer and replace fuse FL221 off pin 11 of the flyback transformer. The convergence power supply is not coming on so system control thinks a convergence circuit is not installed.
No Convergence adjustment option in my RCA Projection TV
please check out the fl231 fuse poblem in the tips and trics under willtab profile you may have this simple repair
1helpful
I WANT TO CONVERGE MY RCA REAR PROJECTION TV. HOW?
Here is a link to the detailed instructions for the RCA ITC222 convergence adjustment proceedure CD with detailed photos.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
1helpful
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if...
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
I think that is the tv, it is HDTV. The convergence is off, and I can't find convergence on the menu. please help!
yesn However if your convergence has disappeared from the menu. et me know and I will assist you its a easy repair and parts with instructions will cost about 12.00
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
1helpful
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
