Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I am having nikon d40 with 18-55 lens. when i press the shutter button there a noise (might be in the lens) and r07 appears in the viewfinder at right hand corner. is that a problem or its normal?
Posted by samaypreet on
  • kakima May 11, 2010
    The r07 is perfectly normal; it's merely an indication of how many more shots you can take in the current burst before the buffer fills up.
    As to the sound... There will be some sound no matter what, due to the mirror flipping up and back down, and the shutter opening and closing. If autofocus is turned on, there will be some sound as the lens turns, even with the so-called "Silent Wave" motor. However, it shouldn't be a loud noise.
    What happens if you turn autofocus off? Can you try your lens on a different camera, or a different lens on your camera?
RAJDEEP DUTTA
  • 2,517 Answers
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck & you get the noise. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Posted on Apr 07, 2010
My nikon d3100 is saying error press shutter release button again and it dont do nything.. it also has a dark blurry film when i look through the lense ?
Hey Julie,
We'll solve your problem in a moment.
Step 1,
First, I need you to look through the viewfinder, and press the shutter release button, half-way, and notice the difference. Don't let go, till you hear a beep sound. The blurriness that you see will clear automatically.
If you hear no noise, and the blurriness doesn't go, try this.
Step 2,
On the lens, there will be a tiny button. It'll have A-M on it. Switch it to 'A', if not already on it.
Once you do that, try step one again. Now, you'll be able to overcome your problem.
Toodles,
Rebel!
Sep 18, 2011 | Nikon D3100 Digital Camera
I have a Nikon d50, had it since 2006, I took a picture, heard a weird noise, and now the viewfinder is dark as if I have a lens cap on (I don't!) I took off the lens and saw inside the body of the...
Inside the camera is a mirror which reflects the scene up to the viewfinder. It flips out of the way when you press the shutter button. When the mirror flips up, the shutter opens and exposes the sensor. When you look inside, if the mirror is stuck in an up position, you will not see anything in the viewfinder. However, the mirror is super delicate....do not touch its surface or try to force it.
Sep 10, 2011 | Nikon D50 Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
I have nikon d40 with 18-55 lens. when i press capture button there is a noise(i think inside the lens) and r07 displays in the viewfinder at right hand side corner. is that a problem or its normal?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck & you get that noise. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 07, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Hi i have a nicon d70 it was working fine when taking photo's on saterday went to change lens from sigma 28-70 to sigma to sigma 75-300 and it came up with error code R07 and noththing worked changed back...
Have you tried formating the memory card? R07 means it has 7 shots in internal memory. Since you have already pressed the reset through the small hole in the front, if formatting the card does not work, try downloading the latest firmware from Nikon and installing it.
Mar 22, 2010 | Nikon D70s Digital Camera
My d80 with 18 - 135 mm lens often does not work in the automatic mode and the screen shows 'r07'. It works in all the other modes and sometimes even the automatic mode will work. Any suggestions? VM
What focus mode? In AF-S the shutter won't release until focus is acquired.
The r07 isn't an error. It's simply telling you how many more pics you can take in burst mode before the buffer fills up.
Dec 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
I followed the instructions in the manual, and put new batteries in + side up. Then I continued with the rest of that step, but I did not see a flashing red LED light anywhere. I do not understand what to...
A few things to try, based on my FG's operation: - The most obvious- are your batteries good? Correct type? If they are: - When all is well the red LED metering lights will appear in the viewfinder window on the right side, in the range of shutter speed numbers. - The red LED metering lights are only activated when you press the shutter release button (halfway). The lights go out after a few seconds if the shutter button is not held down. Just tap the shutter button to reactivate them. - The shutter speed setting dial must NOT be on B (Bulb) or M90 (non-electronic Manual mode) if you want to see the red LED metering lights. The lights do not operate on these two settings because metering is irrelevant here (you'd be doing the metering, not the camera). - If you're in P (Program mode) the lens aperture must be set all the way to the smallest setting (usually f22 or f16, depending on the lens). If not, you'll only see blinking lights at the top and bottom of the shutter speed range on the right in the viewfinder. That's a reminder to set the lens to the smallest (highest numeric) aperture.
Hope these help. The FG is a great little camera.
Aug 14, 2009 | Nikon FG 35mm SLR Camera
"Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Video screen won't work
If you are talking about viewing the shot you just took, press the "info" button on the top of the camera (next to the shutter button), that will turn the LCD on and off.
Oct 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
290 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
