Question about HP Photosmart 3210 Printer
3210 printer won't respond!!! I cannot print out anything on this printer, but it was working one month ago!?!?!
Posted by willhodges on
Anonymous
    Novelist:
  • 91 Answers
Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (3210 printer won't respond!!! - c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this hap3210 printer won't respond!!! - c01602202.gifnd quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Posted on Apr 07, 2010
hptechnicalsupportnumber
    Sergeant:
    Habit-Forming:
  • HP Expert
  • 81 Answers
For working of your HP Printer just dial our **HP Printer Technical Support Phone Number 1(844)355-5111 available anytime for your full support.
Related HP Printer query just dial our toll free number 1(844)355-5111
HP Printer Support Phone Number 1 844 355 5111
3210 printer won't respond!!! - 1(844)355-5111 hp printer technical support phone number-52nrlvis4s32lueowwv1mvpo-5-0.png
Posted on Nov 10, 2017
HP Photosmart 3210 -Ink System failure - Error 0xc18a0001
In addition to having the ink system failure error 0xc18a0001, my printer screen also read improper shutdown. After trying most of the above solutions with no success, I did a search for the improper shutdown problem. This is where I found my solution!
The solution is under "Printer will not start" the solution post is by speters9971. "...you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord."
This is what solved my problem after hours of searching & repetitive similar solutions!!! The above solutions did not help; some of them seemed to be incomplete or irrelevant for my model. I have a HP Photosmart 3210 All-in-One.
Thank you speters9971!!!!!!!
May 27, 2008 | HP Photosmart 3210 All-In-One InkJet...
Printer not responding
Hi
Turn the printer off and on.
Try disconnecting the printer completely from power and from PC and re-connect again.
Mar 30, 2012 | Canon Pixma MX410 All-In-One Printer
I have a HP 3210 All-in-one printer that I am having problems with. Whenever I print a picture or anything is certain colors I get stripes. It works fine in black and white. I have replaced all of the ink...
the nozzles are clogged most likely. try to clean it by using the software provided. another thing is try to align the print heads. that's also included in the software for the printer.
Jun 25, 2010 | HP Photosmart 3210 All-In-One InkJet...
What kindof printer doyou recomend fora hp2009m slimline desktop
Almost any HP, printer. Depends on how much volume your going to do and the speed you want.
I don't care what anyone anywhere says. No one can touch an HP for reliability. I service those at several Universities and Hospitals and have several of the small HP laser printers with well over a million pages on them. Some in the 2 million page count. You throw in a maintenance kit every now and then and they just flat out run.
I have serviced Lexmark, Xerox, Sharp, Canon,Ricoh and some other off brands. I do NOT sell anything, so to take the sales point of view out of it. I see the productivity and longevity of the HP printers every day I work. They have no close competition. They are in a class of their own.
Mar 31, 2010 | HP DeskJet F380 All-In-One Printer
I just got this printer like a month ago from my
I would reinstall the driver from www.support.dell.com
Jun 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
My printer doesn't print anything
Head problem COPY many black text pages 50 or so run head clean if still white pages repeat up to 200 or so pages..see how you go
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
HP 7180 ALL IN ONE WON'T PRINT
Take it back. It's under warranty. Check scanner is not good
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
Hp 3210 issue, keeps printing something from memory over and over
i can't help you!!! but duh???? you could try buying a new one than sacrifice for that F**k!!!
Jul 14, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
875 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
