Your TV is so-called V-36 chassis.
First shut off TV and unplug it from the wall.
On the back of the TV on the right hand side if look from behind you can locate plastic lamp cover that is removable. Behind the cover you will see lamp cartridge that held in place by screws that you have to loose using screwdriver. Remove lamp assembly and install the new one. Make sure that cartridge is all way in, you have to feel connection plug to be slide-in all the way. Tighten up screws but not too hard.
Reinstall lamp cover. Plug TV into the wall and wait for green LED light to stop blinking. Turn TV set on. It should display message "Power loss, did you replace the lamp?" You hit "enter" on your original Mitsubishi (not the cable box or Satellite box) remote control and this is it.
Regards.
Russ.
I have too many star in my tv ?
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
SOURCE: where can I buy and how much is a light engine for
Mitsubishi parts can be purchased at authorized service centers for around $450. Other distributors may carry Mits but the price will be higher. Part number is 938P019010. We are also a Mits authorized center. Thx
Bill W.
integrityhomeworx.com
