Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Not able to configure my router
Not able to configure my wbr1310 router. I already have wireless device from my cable company and it only supports 5 devices. I am trying to add wbr1310 to my network to add more devices. followed instructions on how to setup and not able to configure
Posted by rsk2002 on
Prashant M
  • 2,277 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on Apr 07, 2010
How to connect the system to the computer.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (WPA or WPA2 encryption) Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Nov 09, 2012 | D-Link 802.11g Wireless Router WBR-1310...
RTA1025W
http://192.168.0.1
Sep 17, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Hello, I've had my D-Link router for about 5 years now. The model is WBR-1310. The connection worked fine up until today. I took off the connectivity between the router and my PC about 6 months ago,...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Secure my router
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
Jul 20, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Lost my cd for wbr 1310 wireless router. I need to install my router to my new computer. Need help please.
You do not need an installation CD to configure the D-Link wireless router
http://192.168.0.1
You now configure the wireless card in your computer with the D-Link's wireless settings so the computer can connect to the D-Link via the wireless.
Apr 16, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I need to enter my code
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a D-Link 802.11g/2.4GHz, but no set up disk and it won't work automatically. Is there a setup that I can download?
You do not need a setup disk to configure the D-Link, just connect a LAN cable from the computer to the wireless router, open a browser and enter the configuration URL. The LAN cable is removed after configuration.
Click on this link for instructions to configure and secure the D-Link and to configure the wireless card in the computer/laptop :-
The D-Link URL is http://192.168.0.1
Default login = admin
Default PW = blank (ie. nothing)
Should you need further assistance please leave me a comment.
Dec 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need to know how to hook up my router and where the cables go i have the basic idea but need help
Dear,
1. connect the cable from the modem to WAN port 2. configure one IP for WAN port in the sebnet of modem (say 192.168.1.x) 3. Configur differnt subnet to the LAN (say 192.168.0.x), you can enable dhcp server router
This will help you more
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip for any help. feel free to contact
Oct 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How to install dlin router
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 05, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
