HOW CAN I RESET TO THE FACTORY DEFAULTS SO THAT I CAN MAIPULATE THE PICTURE MODE FROM THE REMOTE? PRESENTLY I CANNOT PERFORM ANY PICTURE MODE CHANGES AND THE TV APPEARS TO BE STUCK IN THE NORMAL SETTING, WHICH IS NOT FULL SCREEN.
Re: HOW CAN I RESET TO THE FACTORY DEFAULTS SO THAT I CAN...
If you are connected to a cable box or satellite receiver and it is high definition (hdmi or component cables) you would manipulate the screen size with the hd zoom, aspect, or format button on the cable or satellite company's remote.
If the television remote control also has it you would further adjust the screen size with a view mode, aspect, or format button
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below. CCTV Networking Technical Support
How do I reset the picture on my LCD TV to the factory settings? The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
If the WIDE button on the remote control isn't changing the aspect ratios here is what I can tell you:
Normal is not available when you are watching a 720p, 1080i or 1080p source.
If 4:3 Default is set to anything but Off, the Wide Mode setting changes only for the current channel. When you change channels (or inputs), Wide Mode is automatically replaced with the 4:3 Default setting for 4:3 sources. To retain the current Wide Mode setting as channels and inputs are changed, set 4:3 Default to Off.
4:3 Default is not available if Auto Wide is set to Off.
If you still can't get the aspect ratio to properly work you may need to do a power reset or perform a factory reset: https://us.en.kb.sony.com/app/answers/detail/a_id/38403/c/65,66/p/61659,62766,63066/ Just make sure to note any special picture or sound settings you may have made.
Your particular TV does not appear to have a "reset" mode to return to default (factory) settings. I can only assume that you are trying to get the picture back to "normal".
To do this grab your remote, press the "menu" button then select "picture' using the up and down buttons. Then press "enter" again and select "mode" this is where you can change the size, aspect ratio and etc. of your picture. Use the up and down buttons to select 16 by 9 format or "standard" if it says that in the menu. The image I have is too small for me to read exactly which setting it should be at. At least this is where you change those options I am pretty sure you will know which setting by checking the video. If it's still wrong then try some of the other "modes" and check again.
Hi there can only try and I hope it will do the job for you. Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. or 2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy. Or try Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
Press the Mode button several times until the Copy LED is lit.
Press the Menu button until Set Defaults is displayed, then press the Select button.
Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
Enter the time, date and language, the press the Select button.
Reset Factory Defaults on the Dell™ 962 Printer To reset factory defaults on the printer, perform the following steps:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
go to service mode, press 5 & 0 on remote, all data will intilize and default data will be written now save data on memory by pressing mute & 0 on remote.
you need to adjust horizontal, vertical and pin geomatry adjustments after above default data setting procedure to view correct aspect picture ratio on screen.
Hi, You cannot exactly reset the whole TV, but you can press the PMode button on your remote control a few times to cycle through all the picture modes (Dynamic, Standard, etc.) in order to factory reset each picture mode.
